Full Version: KC868-AP ESPHome demo config for home assistant by ethernet
  encryption:
    key: "hx8eSqbwjWs9/2bK0qK55QfTIOpI4gCfzLOeaOXZMaU="
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 16
  - id: 'pcf8574_hub_in_1'  # for input channel 1-8    maybe 0x22  /  0x3A
    address: 0x3A
    address: 0x21
      pcf8574: pcf8574_hub_in_2
      number: 34
      number: 35
pca9685:
    frequency: 500
output:
  - platform: pca9685
    pca9685_id: 'pca9685_hub'
    channel: 0
  - platform: pca9685
    channel: 1
  - platform: pca9685
    channel: 2
  - platform: pca9685
    channel: 3
  - platform: pca9685
    channel: 4
  - platform: pca9685
    channel: 5
  - platform: pca9685
    channel: 6
  - platform: pca9685
    channel: 7
  - platform: pca9685
    channel: 8
  - platform: pca9685
    channel: 9
  - platform: pca9685
    channel: 10
  - platform: pca9685
    channel: 11
  - platform: pca9685
    channel: 12
  - platform: pca9685
    channel: 13
  - platform: pca9685
    channel: 14
  - platform: pca9685
    channel: 15
light:
  - platform: monochromatic
    output: PWM0
    output: PWM1
    output: PWM2
    output: PWM3
    output: PWM4
    output: PWM5
    output: PWM6
    output: PWM7
    output: PWM8
    output: PWM9
    output: PWM10
    output: PWM11
    output: PWM12
    output: PWM13
    output: PWM14
    output: PWM15
  - platform: rgbw
    red: PWM1
    green: PWM2
    blue: PWM3
    white: PWM4
    pin: 13
    inverted: false
    pin: 2
    inverted: false
I have bought this board and am using esphome with this yaml configuration file.
My led strips are flickering when I change the brightness level. Is there a setting to minimize this?
Thank you.
can you take a video? or can you test with another LED strip, different load.
same thing at my side....
its flickering on startup the LED. i remember with other esphome pwm controllers it was possible to fix that with frequency. do we have this option?
# Example configuration entry with external clock enable and clock source from ESP32
pca9685:
- id: pca9685_hub1
external_clock_input: true
# Individual outputs
output:
# generate PWM from ESP32 ledc
- platform: ledc
pin: 25
min_power: 1
frequency: 40MHz
- platform: pca9685
pca9685_id: 'pca9685_hub1'
channel: 0
this is demo code from ESPHome, you can try to change the "frequency" to another value for a test.
details: https://esphome.io/components/output/pca9685.html
It does not work with external clock config, led doesn't turn on...
what's your means?
I have the same problem? its flickering on startup the LED
OK. Problem solved. The default frequency for the I2C bus was too low
you have set higher i2c bus speed for pca9685?
