here is KC868-AP dimmer controller work with DC12V/24V LED strip and wall switch panel.
attachment=1732]
Is it possible to get an 0-10v output from this board instead of PWM?
sure, KC868-AP use for output 0-10v
Is it possible to provide an example config to output 0-10v?
I'm using ESPhome and home assistant.
I'm currently using that config.
Every channel outputs a PWM signal.
I'm trying to do this but with the KC868-AP.
![[Image: attachment.php?aid=1526]](https://www.kincony.com/forum/attachment.php?aid=1526)
sure, just KC868-AP already have led driver circuit on the PCB, KC868-D16 need to add extend led driver.
This my exact setup.
Is there some parameter I need to change to change the current PWM signal?
attachment=1861]
if you want output dc0-10v, you need to use 10v power supply.
