(11-15-2022, 08:30 AM)admin Wrote: [ -> ]sure , our old customer
do you have connect H32 relay output to AC contact? if have, use by H32B need add RC snubber.
Hi
Yes, I have the motors connected directly to the KC868 board. They are fed from the 220v circuits, but have transformers inside the motor casing to convert to low DC voltage.
In this case I need a RC snubber in each relay output?
do you only use H32 32 channel relay output for curtain motor?
Yes, I use a KC868-H32 to control 16 motors, 2 relays per each motor, one for up and another for down. I am using all 32 relays.
ok, if only connect with curtain motor, no problem, H32B not need connect with RC snubber.
you can contact with seller, do you buy H32 from our aliexpress official store?
(11-15-2022, 09:28 PM)admin Wrote: [ -> ]ok, if only connect with curtain motor, no problem, H32B not need connect with RC snubber.
Yes, I bought from the aliexpress store.
Can you give me the contact of the seller?
which aliexpress store? you can send message to kincony official store aliexpress online store. kincony.aliexpress.com
