Full Version: Colb maximum commands
Hello, in colb pc software,as we know colbs has 16ai and 16 di so imagine i have connected 9 pir sensors and 3 smoke sensors, 2 rain sensors, and i wanted to add IF function for each sensor to control relays (THEN) but as i see that the max commands on IF is only 10 how is this possible? And max commands on then is 50
So how im supposed to control all DI and AI?
[Image: logical-controller-COLB-6.jpg]
IF () () () .........  MAX 10
THEN () () () ...... MAX 50
IF THEN   IF THEN    IF THEN  command MAX 50
you didnt give me a clear answer, i Didnt understand, as i saw there is channels, so does that mean that each channel can have 10 if commands and 50 then commands? And it works automatically? Or its only 10 if and 50 then and thats all? Cause as i said how in supposed to create 15 di if commands if the maximum possible is 10?
each channel can have 10 if commands and 50 then commands? Yes
And it works automatically? Yes
if DI1=x THEN ......
if DI2=x THEN ......
if DI3=x THEN ......
if DI4=x THEN ......
MAX can create 50 lines for 50 IFTTT command.
