Full Version: KC868-A16 home assistant demo configuration.yaml by MQTT
the file is attached.
PS:  While trying to configure the HomeAssistant connection to the A16 in configuration.yaml, I also saw this message:
The esphome integration does not support configuration using a YAML file. You may not notice any obvious integration issues, but any settings defined in the YAML won't actually be applied. To solve this:
1. If you haven't already done so, set up the integration.
2. Remove "esphome:" from the YAML settings file.
3. Restart Home Assistant.
this is configuration.yaml.
you need to intsall ESPHome addon on home assistant firstly.
then use this A16's yaml to create device in ESPHome, here is demo yaml file for A16: https://www.kincony.com/forum/showthread.php?tid=1628
The ESPHome addon has long been installed in HomeAssistant.
Thanks for the link to the contents of the YAML file for A16.
But I still don't know where this file should be saved? How to integrate?
...so far I haven't found a procedure that I can replicate on my H.A..
add whatsapp number: +86-15381188302
we use "ANYDESK" software remote control your computer to help you.
A note for people using the HA YAML, you can get better information on temperature/humidity data in HA if you provide it with a better description of what the sensors are:
mqtt:
    - name: kc868_temperature_1
      unique_id: uniqueid__kc868_temperature_1
      icon: mdi:thermometer
      state_topic: "KC868_A16/1234ABCD/STATE"
      value_template: "{{ value_json.sensor1.temperature }}"
      unit_of_measurement: "°C"
      device_class: temperature
    # Note that the docs misspell this as "humity", it's actually returned
    # as "humidity".
    - name: kc868_humidity_1
      unique_id: uniqueid__kc868_humidity_1
      icon: mdi:water-percent
      value_template: "{{ value_json.sensor1.humidity }}"
      unit_of_measurement: "%"
      device_class: humidity
homeassistant:
  customize:
    sensor.kc868_temperature_1:
      friendly_name: "Temperature"
    sensor.kc868_humidity_1:
      friendly_name: "Humidity"
(02-02-2025, 12:44 PM)twostar Wrote: [ -> ]A note for people using the HA YAML, you can get better information on temperature/humidity data in HA if you provide it with a better description of what the sensors are:
mqtt:
    # as "humidity".
homeassistant:
  customize:
yes, it's right.
    - name: kc868_adc_1
      unique_id: uniqueid__kc868_adc_1
      state_topic: "KC868_A8S/1234ABCD/STATE"
      value_template: "{{ value_json.adc1.value }}"
this use for adc1, you can also config for adc2, adc3, adc4.
mqtt state message feedback as this format:
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"output1":{"value":false},"output2":{"value":false},"output3":{"value":false},"output4":{"value":false},"output5":{"value":false},"output6":{"value":false},"output7":{"value":false},"output8":{"value":false},"output9":{"value":false},"output10":{"value":false},"output11":{"value":false},"output12":{"value":false},"output13":{"value":false},"output14":{"value":false},"output15":{"value":false},"output16":{"value":false},"adc1":{"value":0},"adc2":{"value":0},"adc3":{"value":0},"adc4":{"value":0},"sensor1":{"temperature":13.5,"humidity":-100},"sensor2":{"temperature":13.375,"humidity":-100},"sensor3":{"temperature":13.5,"humidity":-100}}
