Full Version: Read Anolog PIN A3,A4
i use this simple code for read value from pins anolog input (0-5V) PIN A3 and A4. At pin A3 connect 0V at pin A4 connect stable 2.5 V and reading value.
#define ANALOG_PIN_A3  32
#define ANALOG_PIN_A4  33
pinMode(ANALOG_PIN_A3,INPUT);
pinMode(ANALOG_PIN_A4,INPUT);
int analog_value_3 = 0;
int analog_value_4 = 0;
analog_value_3 = analogRead(ANALOG_PIN_A3);
analog_value_4 = analogRead(ANALOG_PIN_A4);
Serial.printf("Current reading on Pin (%d)=%d\n",ANALOG_PIN_A3,analog_value_3);
Serial.printf("Current reading on Pin (%d)=%d\n",ANALOG_PIN_A4,analog_value_4);
delay(2000);
At serial monitor i see this result
Current reading on Pin (33)=1889
Current reading on Pin (32)=0
Current reading on Pin (33)=1872
Current reading on Pin (33)=1875
Current reading on Pin (33)=1920
Current reading on Pin (33)=1873
Current reading on Pin (33)=1879
Current reading on Pin (33)=1888
Current reading on Pin (33)=1871
Current reading on Pin (33)=1865
VALUE of PIN 4 (33)  is NOT STABLE the value varies, it pulsates +/-20 or more, max 1920 , minimum 1865. It is normaly ? Can i solve it ?
THX
RHA
Small changes are normal because analog input signals are very sensitive.
