02-25-2023, 10:22 PM
Hello, this year i was finished installation of my new boiler room with 3 boilers, 16 pumps, 16 electric valves, one pellet burner... Now i need to make automation of all components. I was test some process with sonoff TH16 and 4CH pro devices and home assistant, only to see what exactly need and can to controll, and the main problem is that i need a lot of temperature sensors, pressure sensors, ultrasonic sensors, relays, contactors etc.
The best solution is to use home assistant, but if you have some suggestions, i am open
In text bellow i will try to explain what i plan to do, and it would be great that you suggest me components for my automation
I hope that you will understand what i need.
Please suggest me what componnent i should use.
If you need additional information, please contact me
Thanks in advance
- Measure temperature from -25 to 100 C on 42 places, and to have a possibility to controll devices (relays) by that temperature
- Measure water pressure in whole heating system on 10-12 places, and to controll electric valves for water and air accordingly measured pressure
- Measure water level in vertical expansion tank of 1200 lit, and controll electric valves for water.
- Measure level of pellet in pellet tank of 1800 kg (2000 mm height)
- Connect one smoke and fire sensor to controll fan in case of smoke
- Relay output on/off or no/nc for control pumps, burner, electric actuators, lights. Relay for pumps, burner, electric actuators will be controled by measured temperature. All relay outputs will controll electric contactor with 24vac coils.
Thanks in advance
