i have said, i am not test with esphome save data function. you can check esphome whether support it, or search by google whether esphome support it to save data.
(05-07-2023, 09:53 AM)admin Wrote: [ -> ] (05-07-2023, 09:04 AM)OloffSmyth Wrote: [ -> ]I would like to connect a Nextion HMI to a KC868 AIO All in One Controller.
Please advise on best pins to use.
if you not use 4G module, you can use 4G socket's RXD,TXD pin for Nextion display.
Thank you. Please advise if any inputs can read 16KHz digital signal from a Digital
Tacho.
INPUT use by PCF8574 i2c extender chip, it MAX frequency is 100KHz. also you can check with ESP32 datasheet, support INPUT frequency.
