03-09-2023, 02:22 AM
03-19-2023, 02:38 AM
Hello Kincony,
I have success to configure My H32B Pro using apple home kits and also operate using momentary switch through kc868-AK.
When H32b Pro connected with COLB mini + KC868-AK is not working ( Relay cannot operated from switch and or KC868-AK).
I already followed the wiring as you provided in here, unfortunately it is still not working and I have no idea.
Could you give advise what the probable cause?
I attached 2 photos (H32B Pro directly connect to AK and connect to COLB and AK)
[attachment=2142][attachment=2143]
Regards
Aliman
Regards
Aliman
03-19-2023, 04:19 AM
tomorrow make a diagram with KC868-COLB mini for you.
03-20-2023, 08:06 AM
(03-19-2023, 04:19 AM)admin Wrote: [ -> ]tomorrow make a diagram with KC868-COLB mini for you.Thank you for help, the problem solved.
There are because pin 3 and 5 are swapped.
regards,
Aliman
03-20-2023, 08:22 AM
good, here is diagram made for you, by KC868-COLB mini + KC868-AK:
https://www.kincony.com/forum/showthread.php?tid=2703
03-21-2023, 05:31 AM
My COLB mini as desire operate, except internal clock/time will be back to default setting when power supply off and on again
This condition cause we always re-set up the time after power shutdown.
Could you any idea to eliminate this problem?
Thanks,
Regards,
Aliman
Thanks,
Regards,
Aliman
03-21-2023, 05:59 AM
open metal box, install a battery on PCB board socket, that is use for save clock. because the product is send by airplane, so we can't install battery into the box.
03-21-2023, 06:04 AM
(03-21-2023, 05:59 AM)admin Wrote: [ -> ]open metal box, install a battery on PCB board socket, that is use for save clock. because the product is send by airplane, so we can't install battery into the box.
What kind of battery type?
Regards,
Aliman
03-21-2023, 08:53 AM
CR1220 battery.
[attachment=2167]
[attachment=2167]
03-21-2023, 08:57 AM
(03-21-2023, 08:53 AM)admin Wrote: [ -> ]CR1220 battery.
Thank you sir.
I will look for at the market.
Regards,
Aliman
