Full Version: KC868 COLB MINI
I have a device KC868 COLB MINI , i try to configure this by connecting power source and ethernet but i didn't find any ip address in the ip scanner and i dont have any response from the device side.... please help me to configure this
feedbacked to you by whatsapp. maybe your power polar is wrong.
in KC868 COLB MINI controller i have connected both the power and ethernet cables, and switch it into ethernet mode but i didn't get any ip address by the ip scanner... please help...
KC868-COLB and your computer all connect to same router, MUST in same network.
(03-13-2023, 12:33 PM)admin Wrote: [ -> ]KC868-COLB and your computer all connect to same router, MUST in same network.
already connected in same network only...
take some photos let me have a look is better. maybe your scan device tool have not chose the correct network card.
(03-13-2023, 10:43 PM)admin Wrote: [ -> ]take some photos let me have a look is better. maybe your scan device tool have not chose the correct network card.
e.) Hold on Ethenret mode button, when the [yellow and white and blue LED] all is ON, release it, then work mode in “TCP Server” and IP (192.168.1.200) by static mode;
Note: after changed mode, the controller will restart automatically.
The controller default work mode is DHCP and TCP Server mode.
here have details: https://www.kincony.com/how-to-use-kc868...oller.html
you can use kincony scan device tool to find out controller ip.
https://www.kincony.com/download/KinCony...Device.zip
can i control the water float sensor with kc868 colb mini?plz guide me
what's means of "control" ? read sensor data or control a relay?
