05-05-2021, 07:14 AM
improvement:
1. Support MQTT by ethernet.
2. Fixed bug that can't use 2pcs KC868-H32B by WiFI MQTT at the same time. Now no limit, multi controller can be used at the same time.
3. Relay "Momentary Time" extend to "1-10000 seconds"
4. add scan device Broadcast command for UDP. This command for software developer scan KC868-H32B in network.
use local network port=4000 send Ansi-String "scan" to remote IP:255.255.255.255 Port:4001
all KC868-H32B in same network device will feedback: device's IP,Port,UID,type
for example:
send->scan
feedback: 192.168.1.200:4196,uid:xxxxxxxxxxxxxxxxxxxxxxxx,type:H32B
KC868-H32B V4.23 firmware download:
[attachment=206]
for example:
send->scan
[attachment=206]
