Full Version: [Arduino source code for KC868-AM]-05 WIFISCAN_RSSI
/*  KC868-AM wifi scan and print the RSSI*/
#include "WiFi.h"
    // Set WiFi to station mode and disconnect from an AP if it was previously connected
    WiFi.mode(WIFI_STA);
    WiFi.disconnect();
    delay(100);
    Serial.println("scan start");
    // WiFi.scanNetworks will return the number of networks found
    int n = WiFi.scanNetworks();
    Serial.println("scan done");
    if (n == 0) {
        Serial.println("no networks found");
        Serial.print(n);
        Serial.println(" networks found");
       for (int i = 0; i < n; ++i) {
          /*Print SSID and RSSI for each network found
            Serial.print(i + 1);
            Serial.print(": ");
            Serial.print(WiFi.SSID(i));
            Serial.print(" (");
            Serial.print(WiFi.RSSI(i));
            Serial.print(")");
            Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
            delay(10);*/
            if(WiFi.SSID(i)=="KinCony"){
            Serial.print(" (");
            Serial.println("db)");
            delay(100);
    Serial.println("");
    // Wait a bit before scanning again
