Full Version: KC868-AIO ESP32 I/O pin define
ESP32 ANALOG_A1 GPIO36 For (Analog Multiplexer: cd74hc4067) to extend "analog input" 1-16
ESP32 ANALOG_A2  GPIO39  analog input 17
ESP32 ANALOG_A3  GPIO34  analog input 18
ESP32 ANALOG_A4  GPIO35  analog input 19
IIC Bus:A
SDA-A:GPIO4
SCL-A:GPIO16
PCF8575:U40 (output 1-16): 100 100 = 0x24
PCF8575:U41 (output 17-32): 100 101 = 0x25
PCF8575:U42 (output 33-38): 100 110 = 0x26
cd74hc4067
S0-A: PCF8575->U42->P10 (output 33)
S1-B: PCF8575->U42->P11 (output 34)
S2-C: PCF8575->U42->P12 (output 35)
S3-D: PCF8575->U42->P13 (output 36)
free LEDs:
LED-D7: PCF8575->U42->P14 (output 37)
LED-D8: PCF8575->U42->P15 (output 38)
PCF8575:U35 (input 1-16): 100 001 = 0x21
PCF8575:U37 (input 17-32): 100 010 = 0x22
PCF8575:U38 (input 33-48): 100 011 = 0x23
PCF8575:U42 (input 49-58): 100 110 = 0x26
PCF8575->U42->P0 (input 49)
PCF8575->U42->P1 (input 50)
PCF8575->U42->P2 (input 51)
PCF8575->U42->P3 (input 52)
PCF8575->U42->P4 (input 53)
PCF8575->U42->P5 (input 54)
PCF8575->U42->P6 (input 55)
PCF8575->U42->P7 (input 56)
PCF8575->U42->P14 (input 57)
PCF8575->U42->P15 (input 58)
PCA9685: address 0x00
Button-S1: reset
Button-S2: GPIO0
Button-S3: PCF8575->U42->P14 (input 57)
Button-S4: PCF8575->U42->P15 (input 58)
DS18B20/DHT11/DHT21/LED strip -(TP1): GPIO14
DS18B20/DHT11/DHT21/LED strip -(TP2): GPIO5
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD(A): GPIO32
TXD(B): GPIO33
4G GSM Module / Extend serial port:
RXD: GPIO13
TXD: GPIO15
DS3231 RTC module: IIC address 0x68
EEPROM's default I2C address is 0x57
Can gpio05 and gpio14 work at the same time?
I tried on one_wire to define both but accepts one OR the other.
I want dht11 on one pin and DS18b20 on the other.
Do you use KCS firmware or ESPHome?
Esp home.
We need two sensors:
(DS18b20) on Tp1 and dht on tp2.
Can both be used at the same time?
How many on each channel using both channels?
sure, you can use two gpio at the same time.
if you using ESPHome, also support one gpio with multi DS18B20 sensors.
One gpio with many DS18b20
Also the other gpio with many Dht11?
yes, that according to ESPHome, one gpio can work with multi ds18b20 sensors. But one gpio ONLY work with one DHT11 sensor.
I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05.
The code I use (try) is:
one_wire:
  pin: GPIO14
  pin: GPIO05
Sensor
 - platform: dallas_temp
   name: #AIO DS18B20 #1"
   update_interval: 10s
   one_wire_id: one_wire1
 - platform: dht
    model: DHT11
    one_wire_id: one_wire2
    temperature:
    humidity:
The error I get is:
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/aio.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-a...pping-pins
Failed config
sensor.dht: [source /config/esphome/aio.yaml:429]
  'pin' is a required option for [sensor.dht].
  platform: dht
  model: DHT11
  [one_wire_id] is an invalid option for [sensor.dht]. Please check the indentation.
  temperature:
  humidity:
What am I doing wrong? I am using 3.3v for Dht11. Tried 2 different sensors, both same error.
https://a.aliexpress.com/_EIdTg JK
https://a.aliexpress.com/_EQCKU9Q
(04-14-2025, 07:39 PM)xarouli5 Wrote: [ -> ]I have a DS18b20 on GPIO14 and working. Trying to use a Dht11 on GPIO05.
one_wire:
  pin: GPIO14
  pin: GPIO05
Sensor:
- platform: dht
    model: DHT11
    temperature:
    humidity:
The error I get is:
Failed config
  platform: dht
  model: DHT11
  temperature:
  humidity:
you can update your esphome to 2025.3
now the one wire sensor yaml format have changed, you can check with esphome webpage.
For any other looking the same:
The problem was not the version of ESPHome, though I updated had the same error as before.
The code working:
one_wire:
  pin: GPIO14
  pin: GPIO05
#no need to define one_wire2 for a reason I don't understand but it works like this. #
Sensor
- platform: dht
    pin: GPIO05
    temperature:
    humidity:
    update_interval: 60s
