Hi!
Will this board support 24v input voltage? Item description page says 12V/24V, board marked only 12V? REV: 1.3
Thanks.
yes, it support 12v or 24v. do you want use power supply by DC 24v, or want OUTPUT 24v voltage?
(04-13-2023, 12:12 AM)admin Wrote: [ -> ]yes, it support 12v or 24v. do you want use power supply by DC 24v, or want OUTPUT 24v voltage?
24V power supply.
ok, it's no problem. use for 12v--24v dc.
And is it possible to use the same 24VDC power supply for both the A64 and the outputs?
I tested the A64 with 24VDC, but it shows no signs of life. It works with 12V. What could be the problem?
take a whole photo, how you wire.
I am very sorry, it was my mistake. One of the cable connectors had a contact issue. As I was about to take the photo, I found and replaced it, and now it works perfectly.
