Full Version: Timer
Hello
I have a 32 channel relay board to control the blinds on the house. Is it possible to set the relay to turn off after a certain time (1 minute)?
yes, you can update firmware for newest, then you can set relay auto off delay time for 1-1000 second (login by your controller IP in web browser), if you want set for 1 minutes, just set to 60S is ok.
Thank you, where I can download new firmware or software for upgrade?
make sure you are using KC868-H32B, must "B". H32L no this new function.
how to download firmware see this video guide: https://www.youtube.com/watch?v=LLIJe9VT...xX&index=5
(05-28-2021, 03:43 AM)admin Wrote: [ -> ]make sure you are using KC868-H32B, must "B". H32L no this new function.
I have L model. Is any think I can do to get a timer?
if you use KC868-H32L, you can set auto off function by phone app to create "scene" mode. add relay ON and add delay time and add relay OFF is ok. But need relay controller work with internet.
hi i had your same problem using h32L + COL.
however, I have a battery of power relays which, controlled by h32, drive the shutters.
having also the physical buttons in the house I had to use a second contact of all the relays in parallel to send a digital input to COL. then i set that when DI = 1 then after 60 seconds it turns off from k1 to k16.
if use "switch terminal board" can work with curtain. motor(relay) will auto off in 1 minute.
