04-26-2023, 12:48 AM
[attachment=2344]
[attachment=2345]
platform: ESP32
# Example configuration entry
- id: bus_a
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
i2c_id: bus_a
address: 0x23
- id: 'pcf8574_hub_out_2' # for output channel 9-16
i2c_id: bus_a
- id: 'pcf8574_hub_out_3' # for output channel 17-24
i2c_id: bus_a
address: 0x25
- id: 'pcf8574_hub_out_4' # for output channel 25-32
i2c_id: bus_a
address: 0x26
# Individual outputs
pcf8574: pcf8574_hub_out_1
pcf8574: pcf8574_hub_out_2
pcf8574: pcf8574_hub_out_3
pcf8574: pcf8574_hub_out_4
- platform: adc
pin: 34
update_interval: 10s
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
- platform: adc
pin: 39
attenuation: 11db
- platform: adc
pin: 36
attenuation: 11db
[attachment=2345]
platform: ESP32
- id: bus_a
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
i2c_id: bus_a
address: 0x23
i2c_id: bus_a
i2c_id: bus_a
address: 0x25
i2c_id: bus_a
address: 0x26
- platform: adc
pin: 34
attenuation: 11db
- platform: adc
pin: 35
attenuation: 11db
- platform: adc
pin: 39
attenuation: 11db
- platform: adc
pin: 36
attenuation: 11db
