05-02-2023, 07:40 AM
(05-01-2023, 02:23 AM)admin Wrote: [ -> ]see this photo. suggestÂ
- channel 1 connected to LED ceiling lamp which needs 88W power supply
- channel 2,3,4 would be connect to LED spot light where each needs 5W power supply
1,2,3,4 work with photo's point is better. must need connect with DC24v to "orange" terminal, so that current can be split. actually if use on "orange" terminal for some channels output, MAX is 5A. so suggest use two different "orange" terminal connect to your DC24v power supply.
Can you please describe those power supplies which are shown on the picture? i am little bit confused, i dont know if those are different power supplies or one with multiple connections.
But to clarify one thing - you basically saying that LED ceiling lamp should be left alone for one Vin for the first 4 channels to be able to handle such a current?
