Hi dear
Can you confirm me please what is max input voltage range for full scale output for ADC 3 & ADC 4 of KC868-A16
Because For me its going to full scale on 3.3volts.
Imran Alam
it according to your wire quality. this not easy to say, you need to test.
I have calibrator for volt output, I am testing with that by directly applying 0 to 3.3v gradually increasing by key input to calibrator.
its looking strange that was the reason i am asking, there is no cabling involved in my case by the way.
" there is no cabling involved in my case by the way." what's your means?
Just applied calibrator probe on ADC 3 or ADC 4 and GND to see the results
can you take a video of your problem.
Any solution for this issue? I have the same problem with esphome, ADC input of my A16 board (on all channel) shows right voltage up to 3.145V, no more.
It works perfect in range 0 - 3.145V, it shows right value. Above 3.14V it shows still 3.14V.
I used very simple code:
- platform: adc
pin: 39
update_interval: 1s
unit_of_measurement: V
attenuation: 11db
I think it depends on attenuation value. With attenuation: 0, it works only up to 1.1V. According to documentation, attenuation can be set to this values: 0db, 2.5db, 6db, 11db, 12db, auto, but nothing works correctly in range 0-5V.
Thanks for any observations.
M.
