Full Version: New house iot project
Please help me choose and recommend devices for my home automations
Six water leak sensor
Two Humidity sensor
Two temperature sensor
A device that can control
three way or four way light switch
One doorbell chime
One energy meter
which software you want to use? home assistant or tuya app?
I’m using Home Assistant
you can chose KC868-Server (install home assitant) + KC868-A series board according to your load channel.
Okay. How will I wire a 3 way light switch to connect to the KC868 A8 board
connect to KC868-A8's digital input ports.
Thanks. I want to control of a three or four way light switch with a relay switch controlled by KC868-A8s. Do you have a product such as  item “D” in my diagram a “smart relay switch”or recommend a wiring solution to control a digital smart relay switch. I have attached the diagram below.
sorry, i don't understand you , what you want to do?
How do I add KinCony products to control a 3 way light switch
do you want use 3 switch buttons control one relay (lamp)?
