Full Version: Do I have a faulty LAN chip?
I have tried to get the ETH working on my KC868-A8S. I have tried the following:
Binary that shipped with the board - ETH not working.
LAN8720_UDP.ino using static address 192.168.1.200 - debug says connected but it does NOT appear on LAN
KC868-A8S_Digital_input_Web_Server-ETH.ino -using DHCP settings - returns IP address 0.0.0.0 and the following:
E (124) lan87xx: lan87xx_pwrctl(409): power up timeout
E (124) lan87xx: lan87xx_init(491): power control failed
E (124) esp_eth: esp_eth_driver_install(215): init phy failed
I have used the following settings
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
The LAN connection is working, but I do not see any LED activity on the KC868-A8S Physical port:
[attachment=2441]
Any help would be appreciated.
Phil
can you use this code for a test? or download by ESPHome config yaml for a test?
after download firmware, re power on of your board have a test.
(05-20-2023, 12:53 AM)admin Wrote: [ -> ]can you use this code for a test? or download by ESPHome config yaml for a test?
I uploaded the firmware "KC868_A8S_V1.0.10.bin" and the LAN LED's came on, I was able to get the IP address and I was able to ping the device! So the LAN is working Smile
I will try to figure out why I can't get the LAN port to operate. I am using these PINS:
#define ETH_ADDR 0
maybe you have not add :
#define ETH_ADDR 0
(05-20-2023, 11:55 AM)admin Wrote: [ -> ]#define ETH_ADDR        0
#define ETH_ADDR        0
Thank You, yes I had forgotten the define for ETH_ADDR
I have now got the unit connecting via Static IP (which is what I need) to a router. I have to travel next week but I will upload a video on my YouTube channel when I get back.
Many thanks to you sir.
you are welcome. if you uploaded video on your YouTube channel, you can leave a URL link. let's watch it Smile
