Full Version: Mqtt and switches
Hi , I d like my switches to not act on my relays. And instead, they should send MQTT messages stating "switch 1 action ON". I tried according to the tasmota pages https://tasmota.github.io/docs/Buttons-a...ion-switch to do it, setoption 114 ou 15, but I dont see any mqtt message when pressing a switch. Can you help?
SwitchMode1 1
SwitchTopic 0
Rule1 on Switch1#state=1 do publish stat/%topic%/PIR1 ON endon on Switch1#state=0 do Publish stat/%topic%/PIR1 OFF endon
Rule1 1
i think you can do as this, such as the PIR sensor:
https://tasmota.github.io/docs/PIR-Motion-Sensors/
The pb is that I have not yet learn the arduino stuff. Any possibility to update the bin file for me?
you are seeing tasmota solution. it's not use by arduino code. just set config as tasmota's guide.
