Full Version: Connecting the switch indicator LEDs
Hi.
The switch panels sold in Kincony's store have light indicators on them with a separate connection socket outlet. Does one of your products have a *digital output* option that can conditionally feed 12VDC to these LEDs? If not, is there another solution (assuming we don't want to connect it directly to the relay's output 320VAC nor having a dedicated expensive contactor for each led)?
Thanks!
Yes, our switch panel have LED indicator. the economical feedback solution is :
let relay controller output DC12V -> middle relay or SSR or AC contactor -> load (like lamp, socket) this DC12V just connect with power supply, so that you not need every channel have a independent DC12V power supply for feedback.
the middle relay can use removable relay (AC230V 16A) , so that if broken, can easily to replace.
Thanks. This is indeed a good solution!
