will there be any update for h32L?
H32L not enough memory for firmware update. B series controller use large memory CPU.
Hi
This is very good news, but please don't forget your existing customers.
I hope you will make the software update for KC868-32B
Thank You
Sten
because H32BS have integrated "switch terminal board" , so it can double click function can easy set by webpage. if you are using H32L or H32B, add the raspberry PI running Node-Red can work with double click function by switch panel or zigbee switch panel.
Is the H32B supporting double click and if yes, how? Do you have some details , knowledge base article or video tutorial?
now H32B not support double click directly. But we are designing new "switch terminal board" , will support this function in furture.
(11-02-2022, 09:59 PM)admin Wrote: [ -> ]now H32B not support double click directly. But we are designing new "switch terminal board" , will support this function in furture.
thanks. Anything indirectly? I'm planning to integrate the H32B with a Loxone miniserver Gen2. I also have a switch board.
if you integrate to Loxone, you can make double-click function by Loxone mini server's software. H32B relay controller just do actions.
Hi
When it could be released?
Regards
Sten
