Full Version: Custom Control Box
Dear team,
do you also do custom control boxes? In my case I‘d need a KC868-a64, about 8 holes for lamps/switches and a LCD display.
Let me know if you do custom configurations, so I can support more details. This is for a prototype that might become series.
ok, list your details.
Sure… So…
Version 1:
- Control/Distribution Box with KC868-A64 ready build-in on DIN rail, clear cover.
Version 2:
- same as above, but…
- grey cover
- 6x 22mm hole for switches/lights, ready with cables attached to I/O ports of the board (will provide details)
- 20x4 CharakterI2C LCD display build in front plate (above holes), ready with cables attached to the I2C port of the board
- Ethernet port socket on the bottom of the box, ready connected to the Ethernet port of the board
Version 3:
- same as Version 2, but…
- add 32x M8 male socket (4 pin) rear mounted on the bottom of the box, ready with cables attached to I/O
- add 4x M12 male socket (8 pin) rear mounted, on the bottom of the box, ready with cables attached to I/O
sorry, we can't do this custom case. i think you can find a box make it by yourself.
