In your application kc868-A8 v2.0.1.bin rf works great there is no reception problem there may be a problem with my code please go through the code I uploaded here I would be very happy if you could help me for two months now I have been on this it is really urgent thank you very much
tomorrow will take video for you and upload this video tour on our YouTube channel.
platform: ESP32
remote_receiver:
pin: 15
dump:
- rc_switch
tolerance: 50%
filter: 250us
idle: 2ms
buffer_size: 2kb
remote_transmitter:
pin: 2
carrier_duty_percent: 50%
# Individual switches
- platform: template
name: RF Power Button
turn_on_action:
- remote_transmitter.transmit_rc_switch_raw:
code: '001111010111001010111000'
protocol: 1
repeat:
times: 10
wait_time: 0s
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
Thanks, I'll check the question if it also includes Laram and Transmit?
If I could use your software to connect to ina226, all the trouble would end in esphome, unable to teach the remote in any way, I don't understand there is software, why not expand the possibility or give open source and we will open the sequel and send you a repaired sister-in-law, I am on top of a product correspondence, there is a solution to something we described with you before shopping.
Hi, I wrote a firmware code in integrated html and I want to convert it to a file between uploading to the firmware, how do I keep the pages to .bin, do you have a suggestion
sorry, i don't understand you.
Hi, I created a site in html and scripts to activate the firmware, in order to load the code, I need to convert the code to a .bin file. Do you have a script to do the conversion for me? for board kc868-A8
