I want to use the tasmota for the analog sensor 4 .... 20mA this can be done
yes, if you use KC868-A4, here are 2 channel of analog 4-20mA input ports you can use. you can integrate with tasmota.
i heave this error when run the bord some time Connecting to AP1 jeg45 in mode 11n as tasmota-C792FC-4860...
pls help
[13:20:31]00:02:23.248 WIF: Connecting to AP1 jeg45 in mode 11n as tasmota-C792FC-4860...
[13:20:42]00:02:35.140 WIF: Connect failed with AP timeout
do your A4 work as "AP" or your A4 is connect to your router's wifi?
No work of Ap.... but i solve this problem
Tnk
I've been trying for a few days in Tasmota to be able to start one of the 4 relays with a 4 ... 20ma sensor but I can't.
I only managed to see what that relay indicated.
Maybe you can help me with some tips
![[Image: KC868-A4_02.jpg]](https://www.kincony.com/images/KC868-A4/KC868-A4_02.jpg)
see this diagram, A1 and A2 are for analog sensors (4-20mA) to use. use this sensor, you should prepare power supply for yourself. let A1 or A2 series connection with your sensor circuit.
Yes i know this but in progam only i see a value but i not cane to start one relay
I not know to build some rule if ned
do you have used ESPhome?
