Full Version: KC868_A64
Dear Admin
After KC868_A64 update to KCS 2, there is probeb to stay online.
Every time when I press SAVE button, I have to make the power restart to the A64 board. Without restart the board is offline, the device scaner does not see the A64 board.
And sometimes Tuya app does not see the A64 board, then I have to make the power restart.
I made a restart to my router and tried another router also.
What can be the problem?
Regards
Sten
which firmware version you have installed? try to use this version: [attachment=2768]
(08-06-2023, 11:41 PM)admin Wrote: [ -> ]which firmware version you have installed? try to use this version:
KCS V2.06
try to test with this new versoin:
[attachment=2774]
(08-07-2023, 05:05 AM)admin Wrote: [ -> ]try to test with this new versoin:
I did the update, but same problem.
If I connect my pc to KC868_A64 WIFI, then I can do the settings and save, not need power reset all the time.
With lan connection it does not work.
if power restarted, A64 can work well with ethernet?
(08-07-2023, 10:03 PM)admin Wrote: [ -> ]if power restarted, A64 can work well with ethernet?
now the device scanner dont see ethernet at all. And if ethernet is connected, then the board freeze. The input (wall switch) click dont do anything. And if I look the monitor screen, then input LED does not react.
Is it possible, that someone come to my computer via Teamviewer?
(08-08-2023, 04:52 AM)Sten Wrote: [ -> ]
can you  take a  photo of your A64 board about the Ethernet port? we think the chip of ethernet maby something wrong with it
(08-08-2023, 07:24 AM)KinCony Support Wrote: [ -> ]
Here are the pictures
As I understand the board hardware is defective.
The board is ca 5 months old, do I have a warranty for this board?
