Full Version: KC868-E16T Factory Original Firmware added RF remote code
Here is Factory Original Firmware for KC868-E16T. You can use Tuya mobile phone application directly. it supprt remote control by internet and manual control buttons and on board. Support learn RF signal send control for relay.
firmware BIN file download: [attachment=2866]
about ESP flash tool download link and details see here : https://www.kincony.com/esp-module-flash...tools.html
[attachment=2867]
arduino source code download:
[attachment=2868]
How does KC868-E16T learn wireless signals see here: https://www.kincony.com/forum/showthread.php?tid=3169
(08-21-2023, 02:09 AM)admin Wrote: [ -> ]Here is Factory Original Firmware for KC868-E16T. You can use Tuya mobile phone application directly. it supprt remote control by internet and manual control buttons and on board. Support learn RF signal send control for relay.
Thank you will try this within today and provide you feedback
thank you
(08-21-2023, 07:19 AM)Alpha21 Wrote: [ -> ]
Hi Sir.,
i would like to know the step to successfully used rf in e16t please confirm the step
1. Flash the e16t using the file you have shared
2. Using the source code upload the it on the board
3. Attached the 433 Mhz receiver board
4. Learn the remoter
Is this the right sequence?
you not need to use source code. just download BIN file to board by "ESP32 download tool". after download, re power on of your board. then can learn remoter's signal. make sure you can installed RF433MHz receiver module on board .
updated new firmware and arduino source code:
add learn ALL ON/ ALL OFF from RF remote signal.
"HOLD ON" key1,3 for learn "ALL ON" RF signal.
"HOLD OFF" key1,3 for learn "ALL OFF" RF signal.
firmware BIN file download (download by ESP32 DOWNLOAD TOOL at 0x0 address):
[attachment=2919]
here is arduino IDE source code:
[attachment=2918]
(08-25-2023, 12:44 PM)admin Wrote: [ -> ]updated new firmware and arduino source code:
Hi Boss.,
Good day! Can we check because when i code all ON and all OFF i observed that when power is loss., the code also erase and requires button coding again
sorry, don't understand your means.
(10-05-2023, 12:33 AM)admin Wrote: [ -> ]sorry, don't understand your means.
Hi Boss.,
I have tested the KC868-16T when the controller finish learning the button from the RF. Once i have restart the power of the controller, i need to repeat learning the controller using the remote. unlike KC868-e8t even power is retarted it retain the memory from the remote button
ok, we will check.
(10-21-2023, 05:26 PM)Alpha21 Wrote: [ -> ]
Hi Boss.,
We tested the firmware, and when the RF signal was learned successfully, It works forever. whether the KC868-E16T was power off and power on,  the RF signal was still active
