Full Version: Available space is less than 1GB
how can i increase memory on LOCAL SERVER (RASPBERRY PI) – KC868-SERVER
can i used SD CARD ?
sure , if you use home assistsant, you can plugin USB disk. then move data to USB disk, home assistant have this function for move data.
Is it possible for me to use SD card ? as attach
no can't, it's eMMC CM4, only use by eMMC.
thank you for your support
you are welcome.
after i move to USB the system slow down
before that was perfect
i don’t know why this happened
any way to speed up the system?
thank you
it should be the type of usb SSD or normal work fine
use high speed USB disk.
Would be possible to connect SSD disk internally in the case of KC868-Server? I mean, under the black metal lid. Have you ever tried NVMe disks ?
