Dear Admin,
Is possible reading inputs to be store in a variables? Or global variables?
This data in variable can be used in IFTTT logic.
Example: Read status for inputs DI1 and DI2 and store to variables Input1 and Input2, read ADC1 voltage to store in ANALOG variable.
Thank You.
firmware not support variable, but you can config IFTTT command compare with a data.
(11-20-2023, 10:32 PM)admin Wrote: [ -> ]firmware not support variable, but you can config IFTTT command compare with a data.
Hi Admin.
Please, can you post an example for compare with data?
Thank you.
do you want use by sensor? such as temperature? or other analog sensor?
(11-21-2023, 10:18 AM)admin Wrote: [ -> ]do you want use by sensor? such as temperature? or other analog sensor?
Hi Admin... I use LDR as light sensor, by voltage variation is night, day (in the day what luminous changes).
+3,3V--------\/\/\/\/\----------O-------------> IA1
LDR |
# 1kohms
____ GND
This configuration, (IF) AI1 <= value, (DO) DO1 to ON working fine.
I don´t make work configuration using TIME inpit. I try to use IFTTT edit an DI1 and TIME function to set DO1, but the time comparison not work (set 18:00 hrs and change intern current time board 17:59 -> 18:00), I set all flags of week time days (SUN, MOR,..., SAT), but unsucefull.
Examples of configurations would be interesting.
I suggest have a 8/16 booleans memory flags and 8bit memory for analog variables it would be really good, a plus.
Thank You!
if use this case, maybe ESPHome is better, you can config yaml for this will be easier.
now KCS almost used full of memory, it's too much function inside.
