(12-18-2023, 12:23 AM)admin Wrote: [ -> ]use mulit meter test HAv2 OUTPUT1-6 when voltage will change if your turn ON/OFF on home assistant.
Measuring from the outputs to GND, it shows +3.8v and this does not change if i turn the switch on of off in Home Assistant.
when you setup complete in PC config tool.
Do you have click the "ApplyTo" button and "SaveFlash" button? Must need press these two buttons.
(12-18-2023, 10:45 PM)admin Wrote: [ -> ]when you setup complete in PC config tool.
Yes, I pressed "ApplyTo" and then "SaveFlash". See the screenshot of the config i just saved again.
attachment=3770]
can you post the newest yaml with latest KC868-HA component (v3.0.0).
(12-18-2023, 11:09 PM)admin Wrote: [ -> ]can you post the newest yaml with latest KC868-HA component (v3.0.0).
friendly_name: dingtian-4ch
baud_rate: 0
encryption:
key: "XXX"
ota:
password: "XXX"
status_led:
number: GPIO15
tx_pin: GPIO1
rx_pin: GPIO3
baud_rate: 9600
type: JL1101
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
clk_mode: GPIO17_OUT
# The PHY chip has a pin labeled TX_EN that goes to GPIO 21 on ESP
# and the RSTn pin on the phy goes to GPIO0
# Datasheet indicates the RSTn should be LOW to disable the phy and default is high
power_pin: GPIO0
external_components:
- source:
type: git
url:
https://github.com/hzkincony/esphome-kc868-ha
ref: main
kc868_ha:
- platform: kc868_ha
target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
bind_output: 1
bind_output: 2
bind_output: 3
bind_output: 4
bind_output: 5
bind_output: 6
- source:
type: git
url:
ref: v3.0.0
use "v3.0.0" , you have use "main". change it.
i don't know which esp32 board model you are using? i can't see in your photo.
maybe you can exchange RXD and TXD pin define.
Now do you INPUT port for binary sensor work well? only OUTPUT can't work?
(12-18-2023, 11:31 PM)admin Wrote: [ -> ]external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-kc868-ha
ref: v3.0.0
I started with “ref: v3.0.0” and changed it to “ref: main” so I would always have the latest version. But it doesn’t work with either option anyway.
The INPUT binary sensors work perfectly. If i press a button, it registers correctly in Home Assistant.
It’s only the OUTPUT that doesn’t work.
(12-19-2023, 02:41 AM)admin Wrote: [ -> ]ok, later we check.
Thank you very much, I hope to hear back soon
after we tested, when have news, will feedback at here.
