Full Version: need help about uair
hello engineer
I have 3 u air in me project
but their is no more video about this product to show how to use as same as anther product
so please any product .make more more video about that
Because we are technical not engineer ..
so this my problem....I already add u air to my home assistant and cannot how to add any remote signal
and cant control for the RGB
and give me  error IP connection
need help
Huh Huh Huh Huh Huh Huh Huh Huh Huh
attach the Yamal file
here is Uair config yaml for ESPHome: https://www.kincony.com/forum/showthread.php?tid=1450
what do you want to do with Uair?
(10-18-2023, 11:52 AM)admin Wrote: [ -> ]here is Uair config yaml for ESPHome: https://www.kincony.com/forum/showthread.php?tid=1450
I want to controll AC and Tv
yes, use Uair to learn AC or TV remote's IR signal, then use HTTP command in home assistant.
here step by step config
I want to access to remote config page to learn our remote
this is logs
 attachment.......
Hello engineer
I want to integrate  Uair to HA by MQTT
2 lights and an internal sensor
So can you help me edit its code?
I am attaching my code
so could you help me edit it correctly?
it already showed how to integrate Uair internal sensor (ds18b20) and 2 WS2812B RGB led to HA. not use MQTT.
(10-23-2023, 11:58 PM)admin Wrote: [ -> ]it already showed how to integrate Uair internal sensor (ds18b20) and 2 WS2812B RGB led to HA. not use MQTT.
Do you mean that light and sensors work in ESP and IR&RF work in MQTT at the same time?
Can work in MQTT and ESP at the same time?
IF yes tell me how
(10-25-2023, 09:29 AM)ahmedwizza1 Wrote: [ -> ]
IF yes tell me how
Hi,we test the MQTT,it works.you can do like this.
01: config UAIR wifi first
[attachment=3300]
02: set the MQTT
[attachment=3301]
03: set the MQTTBOX message
[attachment=3302]
04: send the Playload message(we send the BEEP ON and OFF command)
here is the command    https://www.kincony.com/forum/attachment.php?aid=2872
[attachment=3303]
mqtt protocol at here: https://www.kincony.com/forum/showthread.php?tid=3105
[attachment=3304]
this showed how to send learned "IR" and "RF" signal by MQTT.
