10-26-2023, 04:41 PM
Hello everyone, I would like to know if there is any way to control 2 more relays, in addition to the 4 that already exist on the board.
Thank you very much in advance.
(10-26-2023, 11:32 PM)administrador Wrote: [ -> ]se você quiser outra placa de 2 relés com porta RS232, você pode conectar com a placa A4. ou você pode usar 2 GPIOs gratuitos conectados ao seu módulo de relé de extensão.
![[Image: relay-2ch.png]](https://i.ibb.co/MZHV9y7/relay-2ch.png)
(10-27-2023, 11:43 AM)admin Wrote: [ -> ]you can use 433M sender's pin and IR receiver's pin (remove IR receiver tube if not need to use it).
(10-27-2023, 11:55 AM)Turbovix Wrote: [ -> ](10-27-2023, 11:43 AM)admin Wrote: [ -> ]you can use 433M sender's pin and IR receiver's pin (remove IR receiver tube if not need to use it).
I see that I have no way out, as I need pin 19 to receive commands from the handheld transmitter.
Therefore, even using the IR pin, I am still missing one.
I'll have to buy another board, I'll look at the KC868-A6 to see if it meets my needs.
Thanks for the help.
I promise it's the last question.
Would it be possible to use the (Beep) pin, capturing before the voltage divider?
