Full Version: RS485 io module - KC868-HAv2 released
HAv2 already have firmware inside, just directly to use. i suggest you received product after a test then post your question.
(02-20-2025, 10:26 PM)admin Wrote: [ -> ]HAv2 already have firmware inside, just directly to use. i suggest you received product after a test then post your question.
Thanks.... delivery is due today so trying to understand where to start.
So does the HAv2 now come with firmware that supports standard modbus, or is it still using a propiatory KCS protocall as suggested by a number of forum posts?
https://youtu.be/S679QX6Hc6I?feature=shared makes it look very easy, and I would just follow that example / code if I could but I need to interface with some other modbus devices too.
Thanks for the help and great products!
HAv2 use by our private protocol, NOT standard modbus. if you want work with home assistant, just do as our video tour.
No, I'm not looking to use with homeassistant (I do use ESPHome and openHAB in my house), I'm looking to interface with openDsh in my vehicle via a python script and some other ESPHome based devices, hence my original questions about   HA485_KU_V108_RIO231124.zip
I guess I'll try and figure it out!
ok
Does this module work with any Kincony board that support RS485 or only with KC868-H32B PRO?
support any kincony esp32 board, work with KCS firmware.
