11-01-2023, 01:57 AM
02-18-2024, 04:34 PM
Hi there,
I have two questions:
- Is the PC Software also available for Linux?
- Is it possible to change the Baudrate of the KC868-HA-V2. I have other stuff on my RS485-Bus which needs different Baudrate.
Thanks very much in advance.
02-18-2024, 07:10 PM
Hi there again,
ok, I found out how to change the baudrate.
I changed it to 57600 baud without parity. That worked.
But I need 57600 baud with parity even. It seems that setting parity doesn't work. I tried it with even and odd.
Could you please check that.
My firmware version is V200
Martin
Martin
02-18-2024, 10:55 PM
how do you use HAv2, HAv2 connect to KinCony's relay board? or HAv2 connect to raspberry pi directly?
02-27-2024, 08:46 AM
(02-18-2024, 10:55 PM)admin Wrote: [ -> ]how do you use HAv2, HAv2 connect to KinCony's relay board? or HAv2 connect to raspberry pi directly?
I connected it to a KC868-AP. But I have other clients on the bus where I cannot change the communication parameters.
Sorry for my late reply. I did not get a notification.
02-27-2024, 10:51 AM
KC868-AP not support HA board.
02-27-2024, 02:46 PM
(02-27-2024, 10:51 AM)admin Wrote: [ -> ]KC868-AP not support HA board.
I already used it with KC868-AP and EspHome. It worked with a slower baudrate.
The only problem I have is that I cannot set the right parity. I think it is a bug in HA firmware.
02-27-2024, 10:24 PM
HAv2 support change baudrate by PC software.
02-28-2024, 07:22 PM
(02-27-2024, 10:24 PM)admin Wrote: [ -> ]HAv2 support change baudrate by PC software
Yes I know. As I said I already did that. But setting parity to anything different than "none" does NOT work. This is why I think there is an error in the firmware of HAv2 or the PC software.
02-28-2024, 09:49 PM
do you means, the partity only work for "NONE"?
