because KCS v2 for KC868-A64 and KC868-A128 sometimes not very stable, not enough memory.
we suggest use this special firmware KCS v1.0.27 for KC868-A64 and KC868-A128.
improvement:
support timer set delay value from (1-65535), before version is (1-255).
I confirm my problem is fixed with V1.0.27 : connexion with ESP HOME is ok . thank you to support for his help. Joined my .yaml config
my yaml configuration that works
Is the problem of memory on firmware V2 on KC868--A64 fixed ? Is it possible to use it ?
Best regards
we suggest to use v1.0.27 for A64 and A128.
if you not use tuya app, you can download KCS v2 firmware for A64. because tuya app will cost many memory.
There is no IFTTT in this version and the input setting for v2+ is limited to Reverse Level only.
yes, because IFTTT not enough memory for A64 and A128.
Hello. how can I use this {"KCS" v1.0.27 firmware for KC868-A64 A128} at the same time with home assistant.
I want those trunks from KCS to continue to be accessed from A128
download KCS v1.0.27 to A128, enable MQTT, use MQTT integrate to home assistant.
Hello.. I got a question ...
I'm gonna use A128 with about 70 inputs and 25 outputs..
ant the only resource I will use is MQTT,
would there be a problem use a newer version with MQTTT?
