Full Version: KC868-A6 Tasmota HA
I have managed to get Tasmota running nicely on the A6, the only issue I have is the integration of the PCF8574 inputs mapped into home assistant.
For some reason, they only show up as sensors. is there a way to map it through?
if you want use A6 for home assistant, suggest integrate A6 to home assistant by ESPHome directly, that will run nicely.
Figured it out,
For those that run into the same issue, make sure you don't modify your MQTT Full topic, keep it the  %topic%/%prefix% and it loads fine.
Think this is just a Tasmota / HA integration requirement with the auto-discovery. I had a similar issue with some Sonoff devices but I fixed it unintentionally lol
ok, great.
