12-07-2023, 08:53 PM
Dear Kincony-Team,
I'm currently looking for a suitable circuit board to realize a new project. At my search I found your website and some boards that could be the right one (for example the KC868-AI) but I’m not sure which one is the right one. Can you possibly tell me if the KC868-AI is the right one respectively which of your boards would be suitable?
I have 13 windows in my house and every window has an sensor for the status (open, closed and tilted). I want to integrate these sensors in my already existing Home Assistant installation. I think the integration via ESP could be one solution.
Here the information about the sensors:
According to the instructions, there are also the following technical data:
Attached you can find an extrude of the installation instructions.
It would be nice if you could tell me if the KC868-AI is suitable. If it is not, which of your boards would be suitable? Is there eventually already a program / yaml for ESP or Home Assistant is existing?
Thank you in advance.
- 7-wire cable
- 2 wires for the sabotage loop / sabotage line
- 2 wires for the signaling contact (generally open/closed)
- 3 wires for the open/tilted state (common "ground")
- General:
- Switch voltage max. 48V DC
- Contact resistance max. 150mOhm
- Surveillance:
- Switching current max. 0.5A
- Transport current max. 1.0A
- Switch performance max. 10W pure ohmic load
- or for the tilt status query:
- Switching current max. 0.25A
- Transport current max. 1.2A
- Switch performance max. 3W pure ohmic load
