Device: K868-AG PRO loaded with 2.2.2 as it, no added component
Blind remote model: AC123-02D
Tried RF learning via the KCS firmware 2.2.2, wasn't successful.
Aircon remote: Mitsubishi Aircon Remote
Tried to IR learn as well, it was successful but unable to transmit.
Any recommendation?
maybe your RF remote wireless code not support, usually use by 433MHz RF EV1527 or PT2262 code.
what about the aircon ir remote able to learn but not able to transmit?
how about other IR device? such TV?
Ok, my fan IR remote works.
This AG is not as I imagine when I buy it, it has definitely the hardware to do what it has but KCS software is really lacking basic function.
Would really want ZIGBEE to be integrated and the 433RF should have more supported protocol.
I kind of know what's going on, please see this:
https://stackoverflow.com/questions/6142...oller-info
Mine is a AG pro, you are right, it has zigbee, but you have to use tasmota and not KCS.
And if I use tasmota, I cannot use the IR or the 433 transceiver.
I am sold by KCS firmware because if IFFT
zigbee mainly use by home assistant work as ZHA component or work as Zigbee2Mqtt.
Don't get me wrong, I have no doubt your hardware covers all these communication components.
But KCS lack the following:
1) Act as a Zigbee Hub, simple ifft control over Zigbee
2) 433MHz should support common blind remote for dooya products and A-ok products.
A BROADLINK RM4 PRO can actually do all with a ready interface.
tasmota also can learn IR and RF signal. they called "RULE" command instead of IFTTT.
