Full Version: ESPHOME 2023.12.0b2 breaking change
Hi Kincony
There is a breaking change in ESPHOME in 2023.12.0b2 that causes the A8 etc yaml to fail the configuration test.
https://github.com/esphome/esphome/pull/5666
I dont have a test system, not sure if you need to add allow_other_uses: true to each pin or a global entry at the top.
If you could advise that would be good
Thankyou..Peter allow_other_uses: true
what hardware resource will can't use?
Hi Kincony
I cannot attach the yaml file (not allowed) or paste it (too big).  This board is A16. ESPHOME 2023.12.0b2. Can I e-mail you he YAML file or is there another way to send ?
Peter
just make ZIP file then upload here. But i don't know what cant' use?
Good day sirs,
my A32 board restarts or resets every 15mins. after it is disconnected from my local home assistant server.
is this normal?
or can we change this from not restarting or reseting when it is disconnected from LOCAL HAS server?
please advise.
thank you.
it's not normal, what power supply you are using?
I am using
MEAN WELL BRAND: EDR-120-12
(電源供庭器)(型就)
INPUT(输入):100:240VAC2.6A
50/60Hz
OUTPUT擀出):12V
10A.
I tried the 12vdc adaptor that comes from your ali express option and this happens, that is why i bought a separate 12 volt DC supply from mean well.
How can i resolve this sir?
if you not use ESPHome, download KCS firmware , whether have this issue?
