Full Version: A24 configure yaml for ESPhome
[attachment=3782]
  platform: ESP32
# Example configuration entry
  - id: bus_a
    sda: 16
    scl: 5
    frequency: 400kHz
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  - id: 'pcf8574_hub_out_1'  # for output channel 1-12 CS1-CS3
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 13-24
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a24--input channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      pcf8574: pcf8574_hub_out_2
      number: 8
      number: 9
      number: 10
      number: 11
# Individual inputs
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_2
  - platform: adc
    pin: 35
    name: "A24 A1 Voltage"
    update_interval: 10s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 34
    name: "A24 A2 Voltage"
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 39
    name: "A24 A3 Current"
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 36
    name: "A24 A4 Current"
    attenuation: 11db
    filters:
  - platform: max31855
    name: "K-Type Thermocouple-1"
    cs_pin:
      number: 13
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-2"
    cs_pin:
      number: 14
      inverted: false
    update_interval: 5s
    name: "K-Type Thermocouple-3"
    cs_pin:
      number: 15
      inverted: false
    update_interval: 5s
spi:
  - id: spi_bus0
    clk_pin: 14
    miso_pin: 12
gp8403:
  voltage: 10V
output:
  - platform: gp8403
    gp8403_id: my_gp8403
    channel: 0
  - platform: gp8403
    channel: 1
light:
  - platform: monochromatic
    output: gp8403_output_1
    output: gp8403_output_2
[attachment=3733]
Hi!
Please post working esphome config, for modbus communication.
I has multiple devices ( ESP32 with ttl converter automatic flow controll, Lillygo can with flow pin controll, Elfin ew11 modbus gateway), and the communication beetween heatpump and Home assistant is working, but with KC868-24 is not.
I use this config:
https://pastebin.com/K71z8P50
do you want A24 work as modbus "SLAVE" or "MASTER"?
(01-10-2024, 09:42 AM)Yocee Wrote: [ -> ]Hi!
I use this config:
I think, i need SLAVE. I want to read and write heatpumps, fancoils, thermostat registers.
if you want A24 work as "SLAVE", you can download KCS firmware, enable RS485 protocol, then it will work as modbus slave.
(01-10-2024, 11:57 PM)admin Wrote: [ -> ]if you want A24 work as "SLAVE", you can download KCS firmware, enable RS485 protocol, then it will work as modbus slave.
Ok, i understand the names. I need MASTER configuration for esphome.
here is video tour about esphome use by MASTER modbus controller:
https://youtu.be/xmBWzVGpggo
Thanks. But that's not what I asked for. I need a configuration file for exactly this panel. It wasn't cheap and so I can't use it.
In the linked video using 13/16 gpio.
draw a paper, what you want A24 to do and your different devices relationship with A24.
(01-12-2024, 12:23 AM)admin Wrote: [ -> ]draw a paper, what you want A24 to do and your different devices relationship with A24.
[attachment=3898]
I am attaching the requested drawing. Please read older post. Please onen links. It's not a complicated task. I was able to solve it with several tools, as I already wrote. Now I want to solve it with the A24 panel.
The task is already done at home with: https://esphome.io/components/modbus_controller.html (auto flow kontroll)
And with this: https://github.com/Xinyuan-LilyGO/T-CAN485 (flow kontroll pin define is requied)
And with this: http://www.hi-flying.com/elfin-ew10-elfin-ew11
And with this: https://github.com/Mosibi/Midea-heat-pump-ESPHome
But I want to solve it with A24.
Here is my not working esphome config.:
[attachment=3899]
