12-22-2023, 09:55 PM
12-23-2023, 01:43 AM
there are sensor's pin define:
Red: DC5V
Black:GND
Yellow:humidity
White:temperature
KC868-A128: A1 and A2 is 0-5v dc analog input ports. A3 and A4 is 4-20mA analog input ports.
your sensor output signal is 0-5v dc. so your sensor RED and Black connect with 5V power supply. Yellow and White cable connect to A1 or A2 of A128 board.
Red: DC5V
Black:GND
Yellow:humidity
White:temperature
11-18-2024, 07:27 PM
Hello!
How and what is the code to integrate a senzor in Home Assistant via MQTT? Where I can found the proper documentation for this?
Thank you!
Thank you!
11-18-2024, 11:09 PM
see here is MQTT document for KCS v2: https://www.kincony.com/forum/showthread.php?tid=3105
