You can help configure the KC868-A16 board so that the UDP
AgIO v5.7 version program works when connected to a computer with a Lan cable, wifi or another way.
I want the output relays to respond to the
section controller.
I don't understand much myself and I don't have any acquaintances who understand network settings very well.
sorry, i don't understand the software. you can check whether the PC software support customsize protocol command. whether can define relay ON/OFF command by yourself.
Can you please check
this code, is it correct? I loaded this sketch, the Lan port is no longer active.
sorry, this need check by yourself.
Members of another forum corrected the section control files, now working.
Maybe there is a printable 3d box file for this A-16 board?
(01-12-2024, 11:15 PM)m_elias Wrote: [ -> ] (01-12-2024, 06:13 PM)zeltini1401 Wrote: [ -> ]Members of another forum corrected the section control files, now working.
Can you share the code?
The author will later post the code on Github.
(01-23-2024, 03:15 PM)zeltini1401 Wrote: [ -> ]The author will later post the code on Github.
Please share the link when it's ready. Thank you!
