01-05-2024, 11:11 AM
[attachment=3854]
[attachment=3855]
yaml download: [attachment=3856]
modbus pull screen setting:[attachment=3857]
substitutions:
max_current_range1: "10"
max_current_range2: "10"
max_current_range3: "10"
max_current_range4: "10"
max_current_range5: "10"
max_current_range6: "10"
max_current_range7: "10"
max_current_range8: "10"
max_current_range9: "10"
max_current_range10: "10"
max_current_range11: "10"
max_current_range12: "10"
max_current_range13: "10"
max_current_range14: "10"
max_current_range15: "10"
max_current_range16: "10"
max_current_range17: "10"
max_current_range18: "10"
max_current_range19: "10"
max_current_range20: "10"
max_current_range21: "10"
max_current_range22: "10"
max_current_range23: "10"
max_current_range24: "10"
max_current_range25: "10"
max_current_range26: "10"
max_current_range27: "10"
max_current_range28: "10"
max_current_range29: "10"
max_current_range30: "10"
friendly_name: m30
# baud_rate: 0
encryption:
key: "8G0kVEA0/DqgAavgKNyy9EYUrWo6pEZM38JVMAryJv8="
ota:
password: "2a26484203d80a83798414c879541760"
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
rx_pin: 32
tx_pin: 33
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
modbus:
uart_id: modbus_uart
modbus_controller:
- id: modbus_hub_m30
address: 1
modbus_id: modbus_hub
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: modbus_hub_m30
address: 100
register_type: holding
unit_of_measurement: A
accuracy_decimals: 3
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_1).state;
float red = (current - 0.0) / ${max_current_range1};
float green = (${max_current_range1} - current) / ${max_current_range1};
float blue = 0.0;
auto call = id(M30_LED1).turn_on();
call.set_brightness(0.6);
call.set_rgb(red, green, blue);
call.set_color_mode(ColorMode::RGB);
call.perform();
address: 101
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_2).state;
float red = (current - 0.0) / ${max_current_range2};
float green = (${max_current_range2} - current) / ${max_current_range2};
float blue = 0.0;
auto call = id(M30_LED2).turn_on();
call.perform();
address: 102
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_3).state;
float red = (current - 0.0) / ${max_current_range3};
float green = (${max_current_range3} - current) / ${max_current_range3};
float blue = 0.0;
auto call = id(M30_LED3).turn_on();
call.perform();
address: 103
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_4).state;
float red = (current - 0.0) / ${max_current_range4};
float green = (${max_current_range4} - current) / ${max_current_range4};
float blue = 0.0;
auto call = id(M30_LED4).turn_on();
call.perform();
address: 104
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_5).state;
float red = (current - 0.0) / ${max_current_range5};
float green = (${max_current_range5} - current) / ${max_current_range5};
float blue = 0.0;
auto call = id(M30_LED5).turn_on();
call.perform();
address: 105
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_6).state;
float red = (current - 0.0) / ${max_current_range6};
float green = (${max_current_range6} - current) / ${max_current_range6};
float blue = 0.0;
auto call = id(M30_LED6).turn_on();
call.perform();
address: 106
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_7).state;
float red = (current - 0.0) / ${max_current_range7};
float green = (${max_current_range7} - current) / ${max_current_range7};
float blue = 0.0;
auto call = id(M30_LED7).turn_on();
call.perform();
address: 107
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_8).state;
float red = (current - 0.0) / ${max_current_range8};
float green = (${max_current_range8} - current) / ${max_current_range8};
float blue = 0.0;
auto call = id(M30_LED8).turn_on();
call.perform();
address: 108
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_9).state;
float red = (current - 0.0) / ${max_current_range9};
float green = (${max_current_range9} - current) / ${max_current_range9};
float blue = 0.0;
auto call = id(M30_LED9).turn_on();
call.perform();
address: 109
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_1_current_10).state;
float red = (current - 0.0) / ${max_current_range10};
float green = (${max_current_range10} - current) / ${max_current_range10};
float blue = 0.0;
auto call = id(M30_LED10).turn_on();
call.perform();
address: 110
unit_of_measurement: V
accuracy_decimals: 1
value_type: U_WORD
filters:
- multiply: 0.01
address: 111
unit_of_measurement: W
value_type: U_WORD
filters:
- multiply: 0.1
address: 112
value_type: U_WORD
filters:
- multiply: 0.1
address: 113
value_type: U_WORD
filters:
- multiply: 0.1
address: 114
value_type: U_WORD
filters:
- multiply: 0.1
address: 115
value_type: U_WORD
filters:
- multiply: 0.1
address: 116
value_type: U_WORD
filters:
- multiply: 0.1
address: 117
value_type: U_WORD
filters:
- multiply: 0.1
address: 118
value_type: U_WORD
filters:
- multiply: 0.1
address: 119
value_type: U_WORD
filters:
- multiply: 0.1
address: 120
value_type: U_WORD
filters:
- multiply: 0.1
address: 121
unit_of_measurement: kWh
value_type: U_WORD
address: 122
value_type: U_WORD
address: 123
value_type: U_WORD
address: 124
value_type: U_WORD
address: 125
value_type: U_WORD
address: 126
value_type: U_WORD
address: 127
value_type: U_WORD
address: 128
value_type: U_WORD
address: 129
value_type: U_WORD
address: 130
value_type: U_WORD
address: 131
value_type: U_WORD
address: 132
unit_of_measurement: Hz
value_type: U_WORD
filters:
- multiply: 0.01
address: 133
unit_of_measurement: °C
value_type: U_WORD
filters:
- multiply: 0.1
# - platform: modbus_controller
# modbus_controller_id: modbus_hub_m30
# address: 134
# register_type: holding
# name: m30_1_tps_2
# id: m30_1_tps_2
# unit_of_measurement: °C
# accuracy_decimals: 1
# value_type: U_WORD
address: 200
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_1).state;
float red = (current - 0.0) / ${max_current_range11};
float green = (${max_current_range11} - current) / ${max_current_range11};
float blue = 0.0;
auto call = id(M30_LED11).turn_on();
call.perform();
address: 201
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_2).state;
float red = (current - 0.0) / ${max_current_range12};
float green = (${max_current_range12} - current) / ${max_current_range12};
float blue = 0.0;
auto call = id(M30_LED12).turn_on();
call.perform();
address: 202
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_3).state;
float red = (current - 0.0) / ${max_current_range13};
float green = (${max_current_range13} - current) / ${max_current_range13};
float blue = 0.0;
auto call = id(M30_LED13).turn_on();
call.perform();
address: 203
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_4).state;
float red = (current - 0.0) / ${max_current_range14};
float green = (${max_current_range14} - current) / ${max_current_range14};
float blue = 0.0;
auto call = id(M30_LED14).turn_on();
call.perform();
address: 204
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_5).state;
float red = (current - 0.0) / ${max_current_range15};
float green = (${max_current_range15} - current) / ${max_current_range15};
float blue = 0.0;
auto call = id(M30_LED15).turn_on();
call.perform();
address: 205
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_6).state;
float red = (current - 0.0) / ${max_current_range16};
float green = (${max_current_range16} - current) / ${max_current_range16};
float blue = 0.0;
auto call = id(M30_LED16).turn_on();
call.perform();
address: 206
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_7).state;
float red = (current - 0.0) / ${max_current_range17};
float green = (${max_current_range17} - current) / ${max_current_range17};
float blue = 0.0;
auto call = id(M30_LED17).turn_on();
call.perform();
address: 207
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_8).state;
float red = (current - 0.0) / ${max_current_range18};
float green = (${max_current_range18} - current) / ${max_current_range18};
float blue = 0.0;
auto call = id(M30_LED18).turn_on();
call.perform();
address: 208
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_9).state;
float red = (current - 0.0) / ${max_current_range19};
float green = (${max_current_range19} - current) / ${max_current_range19};
float blue = 0.0;
auto call = id(M30_LED19).turn_on();
call.perform();
address: 209
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_2_current_10).state;
float red = (current - 0.0) / ${max_current_range20};
float green = (${max_current_range20} - current) / ${max_current_range20};
float blue = 0.0;
auto call = id(M30_LED20).turn_on();
call.perform();
address: 210
value_type: U_WORD
filters:
- multiply: 0.01
address: 211
value_type: U_WORD
filters:
- multiply: 0.1
address: 212
value_type: U_WORD
filters:
- multiply: 0.1
address: 213
value_type: U_WORD
filters:
- multiply: 0.1
address: 214
value_type: U_WORD
filters:
- multiply: 0.1
address: 215
value_type: U_WORD
filters:
- multiply: 0.1
address: 216
value_type: U_WORD
filters:
- multiply: 0.1
address: 217
value_type: U_WORD
filters:
- multiply: 0.1
address: 218
value_type: U_WORD
filters:
- multiply: 0.1
address: 219
value_type: U_WORD
filters:
- multiply: 0.1
address: 220
value_type: U_WORD
filters:
- multiply: 0.1
address: 221
value_type: U_WORD
address: 222
value_type: U_WORD
address: 223
value_type: U_WORD
address: 224
value_type: U_WORD
address: 225
value_type: U_WORD
address: 226
value_type: U_WORD
address: 227
value_type: U_WORD
address: 228
value_type: U_WORD
address: 229
value_type: U_WORD
address: 230
value_type: U_WORD
address: 231
value_type: U_WORD
address: 232
value_type: U_WORD
filters:
- multiply: 0.01
address: 233
value_type: U_WORD
filters:
- multiply: 0.1
# address: 234
# name: m30_2_tps_2
# id: m30_2_tps_2
address: 300
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_1).state;
float red = (current - 0.0) / ${max_current_range21};
float green = (${max_current_range21} - current) / ${max_current_range21};
float blue = 0.0;
auto call = id(M30_LED21).turn_on();
call.perform();
address: 301
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_2).state;
float red = (current - 0.0) / ${max_current_range22};
float green = (${max_current_range22} - current) / ${max_current_range22};
float blue = 0.0;
auto call = id(M30_LED22).turn_on();
call.perform();
address: 302
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_3).state;
float red = (current - 0.0) / ${max_current_range23};
float green = (${max_current_range23} - current) / ${max_current_range23};
float blue = 0.0;
auto call = id(M30_LED23).turn_on();
call.perform();
address: 303
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_4).state;
float red = (current - 0.0) / ${max_current_range24};
float green = (${max_current_range24} - current) / ${max_current_range24};
float blue = 0.0;
auto call = id(M30_LED24).turn_on();
call.perform();
address: 304
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_5).state;
float red = (current - 0.0) / ${max_current_range25};
float green = (${max_current_range25} - current) / ${max_current_range25};
float blue = 0.0;
auto call = id(M30_LED25).turn_on();
call.perform();
address: 305
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_6).state;
float red = (current - 0.0) / ${max_current_range26};
float green = (${max_current_range26} - current) / ${max_current_range26};
float blue = 0.0;
auto call = id(M30_LED26).turn_on();
call.perform();
address: 306
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_7).state;
float red = (current - 0.0) / ${max_current_range27};
float green = (${max_current_range27} - current) / ${max_current_range27};
float blue = 0.0;
auto call = id(M30_LED27).turn_on();
call.perform();
address: 307
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_8).state;
float red = (current - 0.0) / ${max_current_range28};
float green = (${max_current_range28} - current) / ${max_current_range28};
float blue = 0.0;
auto call = id(M30_LED28).turn_on();
call.perform();
address: 308
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_9).state;
float red = (current - 0.0) / ${max_current_range29};
float green = (${max_current_range29} - current) / ${max_current_range29};
float blue = 0.0;
auto call = id(M30_LED29).turn_on();
call.perform();
address: 309
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float current = id(m30_3_current_10).state;
float red = (current - 0.0) / ${max_current_range30};
float green = (${max_current_range30} - current) / ${max_current_range30};
float blue = 0.0;
auto call = id(M30_LED30).turn_on();
call.perform();
address: 310
value_type: U_WORD
filters:
- multiply: 0.01
address: 311
value_type: U_WORD
filters:
- multiply: 0.1
address: 312
value_type: U_WORD
filters:
- multiply: 0.1
address: 313
value_type: U_WORD
filters:
- multiply: 0.1
address: 314
value_type: U_WORD
filters:
- multiply: 0.1
address: 315
value_type: U_WORD
filters:
- multiply: 0.1
address: 316
value_type: U_WORD
filters:
- multiply: 0.1
address: 317
value_type: U_WORD
filters:
- multiply: 0.1
address: 318
value_type: U_WORD
filters:
- multiply: 0.1
address: 319
value_type: U_WORD
filters:
- multiply: 0.1
address: 320
value_type: U_WORD
filters:
- multiply: 0.1
address: 321
value_type: U_WORD
address: 322
value_type: U_WORD
address: 323
value_type: U_WORD
address: 324
value_type: U_WORD
address: 325
value_type: U_WORD
address: 326
value_type: U_WORD
address: 327
value_type: U_WORD
address: 328
value_type: U_WORD
address: 329
value_type: U_WORD
address: 330
value_type: U_WORD
address: 331
value_type: U_WORD
address: 332
value_type: U_WORD
filters:
- multiply: 0.01
address: 333
value_type: U_WORD
filters:
- multiply: 0.1
# address: 334
# name: m30_3_tps_2
# id: m30_3_tps_2
light:
- platform: partition
segments:
- id: light1
to: 14
segments:
- id: light1
to: 13
segments:
- id: light1
to: 12
segments:
- id: light1
to: 11
segments:
- id: light1
to: 10
segments:
- id: light1
to: 9
segments:
- id: light1
to: 8
segments:
- id: light1
to: 7
segments:
- id: light1
to: 6
segments:
- id: light1
to: 5
segments:
- id: light1
to: 4
segments:
- id: light1
to: 3
segments:
- id: light1
to: 2
segments:
- id: light1
to: 1
segments:
- id: light1
to: 0
segments:
- id: light1
to: 15
segments:
- id: light1
to: 16
segments:
- id: light1
to: 17
segments:
- id: light1
to: 18
segments:
- id: light1
to: 19
segments:
- id: light1
to: 20
segments:
- id: light1
to: 21
segments:
- id: light1
to: 22
segments:
- id: light1
to: 23
segments:
- id: light1
to: 24
segments:
- id: light1
to: 25
segments:
- id: light1
to: 26
segments:
- id: light1
to: 27
segments:
- id: light1
to: 28
segments:
- id: light1
to: 29
# Example for light segment source
rgb_order: GRB
pin: GPIO12
num_leds: 30
rmt_channel: 0
chipset: ws2812
[attachment=3855]
substitutions:
friendly_name: m30
# baud_rate: 0
encryption:
ota:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
rx_pin: 32
tx_pin: 33
baud_rate: 115200
stop_bits: 1
data_bits: 8
parity: NONE
modbus:
modbus_controller:
address: 1
update_interval: 5s
address: 100
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 101
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 102
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 103
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 104
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 105
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 106
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 107
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 108
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 109
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 110
value_type: U_WORD
filters:
- multiply: 0.01
address: 111
value_type: U_WORD
filters:
- multiply: 0.1
address: 112
value_type: U_WORD
filters:
- multiply: 0.1
address: 113
value_type: U_WORD
filters:
- multiply: 0.1
address: 114
value_type: U_WORD
filters:
- multiply: 0.1
address: 115
value_type: U_WORD
filters:
- multiply: 0.1
address: 116
value_type: U_WORD
filters:
- multiply: 0.1
address: 117
value_type: U_WORD
filters:
- multiply: 0.1
address: 118
value_type: U_WORD
filters:
- multiply: 0.1
address: 119
value_type: U_WORD
filters:
- multiply: 0.1
address: 120
value_type: U_WORD
filters:
- multiply: 0.1
address: 121
value_type: U_WORD
address: 122
value_type: U_WORD
address: 123
value_type: U_WORD
address: 124
value_type: U_WORD
address: 125
value_type: U_WORD
address: 126
value_type: U_WORD
address: 127
value_type: U_WORD
address: 128
value_type: U_WORD
address: 129
value_type: U_WORD
address: 130
value_type: U_WORD
address: 131
value_type: U_WORD
address: 132
value_type: U_WORD
filters:
- multiply: 0.01
address: 133
value_type: U_WORD
filters:
- multiply: 0.1
# address: 134
# name: m30_1_tps_2
# id: m30_1_tps_2
address: 200
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 201
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 202
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 203
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 204
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 205
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 206
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 207
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 208
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 209
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 210
value_type: U_WORD
filters:
- multiply: 0.01
address: 211
value_type: U_WORD
filters:
- multiply: 0.1
address: 212
value_type: U_WORD
filters:
- multiply: 0.1
address: 213
value_type: U_WORD
filters:
- multiply: 0.1
address: 214
value_type: U_WORD
filters:
- multiply: 0.1
address: 215
value_type: U_WORD
filters:
- multiply: 0.1
address: 216
value_type: U_WORD
filters:
- multiply: 0.1
address: 217
value_type: U_WORD
filters:
- multiply: 0.1
address: 218
value_type: U_WORD
filters:
- multiply: 0.1
address: 219
value_type: U_WORD
filters:
- multiply: 0.1
address: 220
value_type: U_WORD
filters:
- multiply: 0.1
address: 221
value_type: U_WORD
address: 222
value_type: U_WORD
address: 223
value_type: U_WORD
address: 224
value_type: U_WORD
address: 225
value_type: U_WORD
address: 226
value_type: U_WORD
address: 227
value_type: U_WORD
address: 228
value_type: U_WORD
address: 229
value_type: U_WORD
address: 230
value_type: U_WORD
address: 231
value_type: U_WORD
address: 232
value_type: U_WORD
filters:
- multiply: 0.01
address: 233
value_type: U_WORD
filters:
- multiply: 0.1
# address: 234
# name: m30_2_tps_2
# id: m30_2_tps_2
address: 300
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 301
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 302
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 303
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 304
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 305
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 306
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 307
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 308
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 309
value_type: U_WORD
filters:
- multiply: 0.00098
on_value:
- then:
- lambda: |-
float blue = 0.0;
call.perform();
address: 310
value_type: U_WORD
filters:
- multiply: 0.01
address: 311
value_type: U_WORD
filters:
- multiply: 0.1
address: 312
value_type: U_WORD
filters:
- multiply: 0.1
address: 313
value_type: U_WORD
filters:
- multiply: 0.1
address: 314
value_type: U_WORD
filters:
- multiply: 0.1
address: 315
value_type: U_WORD
filters:
- multiply: 0.1
address: 316
value_type: U_WORD
filters:
- multiply: 0.1
address: 317
value_type: U_WORD
filters:
- multiply: 0.1
address: 318
value_type: U_WORD
filters:
- multiply: 0.1
address: 319
value_type: U_WORD
filters:
- multiply: 0.1
address: 320
value_type: U_WORD
filters:
- multiply: 0.1
address: 321
value_type: U_WORD
address: 322
value_type: U_WORD
address: 323
value_type: U_WORD
address: 324
value_type: U_WORD
address: 325
value_type: U_WORD
address: 326
value_type: U_WORD
address: 327
value_type: U_WORD
address: 328
value_type: U_WORD
address: 329
value_type: U_WORD
address: 330
value_type: U_WORD
address: 331
value_type: U_WORD
address: 332
value_type: U_WORD
filters:
- multiply: 0.01
address: 333
value_type: U_WORD
filters:
- multiply: 0.1
# address: 334
# name: m30_3_tps_2
# id: m30_3_tps_2
light:
segments:
- id: light1
to: 14
segments:
- id: light1
to: 13
segments:
- id: light1
to: 12
segments:
- id: light1
to: 11
segments:
- id: light1
to: 10
segments:
- id: light1
to: 9
segments:
- id: light1
to: 8
segments:
- id: light1
to: 7
segments:
- id: light1
to: 6
segments:
- id: light1
to: 5
segments:
- id: light1
to: 4
segments:
- id: light1
to: 3
segments:
- id: light1
to: 2
segments:
- id: light1
to: 1
segments:
- id: light1
to: 0
segments:
- id: light1
to: 15
segments:
- id: light1
to: 16
segments:
- id: light1
to: 17
segments:
- id: light1
to: 18
segments:
- id: light1
to: 19
segments:
- id: light1
to: 20
segments:
- id: light1
to: 21
segments:
- id: light1
to: 22
segments:
- id: light1
to: 23
segments:
- id: light1
to: 24
segments:
- id: light1
to: 25
segments:
- id: light1
to: 26
segments:
- id: light1
to: 27
segments:
- id: light1
to: 28
segments:
- id: light1
to: 29
rgb_order: GRB
pin: GPIO12
num_leds: 30
rmt_channel: 0
chipset: ws2812
