Hi
I connected a DS18B20 temperature sensor. and bind with output1.
I configured if temperature higher than 20'c then output 1 goes high, if temperature lower than 19'c then output1 goes low.
But output1 doesn't move. What I have to do in this situation?
which board you are using?
what firmware you are using?
what setting you have config?
if you want ask one question, please tell us details.
(01-11-2024, 10:28 AM)admin Wrote: [ -> ]which board you are using?
I'm using KC868-A8M controller and KCS V2 firmware.
I set if temperature higher than 20'c, then fan rotated by output 1 relay.
But it doesn't work when temperature higher than 20'c.
(output 1 relay bound with temperature sensor)
I attached picture below
Thank you!
cancel the pop window, i can't see your "IF" setting.
(01-12-2024, 08:01 AM)admin Wrote: [ -> ]cancel the pop window, i can't see your "IF" setting.
take a photo of your "SENSOR" setting screen.
(01-12-2024, 10:12 AM)admin Wrote: [ -> ]take a photo of your "SENSOR" setting screen.
Temperature Threshold set to 0.5
Humidity Threshold set to 1
for a testing
(01-14-2024, 05:42 AM)admin Wrote: [ -> ]Temperature Threshold set to 0.5
for a testing
It's working!! I really appreciate your help!
Have a nice day ^^
