Full Version: 433mhz motion sensor
    I have a KC868-A16 running KCS firmware v2.2.2 and I am thinking of using it to replace my alarm system control board and use a Home Assistant alarm entity...  integrating the KC868 I/O using MQTT was pretty easy However, I also have a few 433mhz motion sensors I'd like to uses and was wondering if it is possible to integrate the 433Mhz Motion sensor into home assistant via the KC868-A16 board?  The KC868 board instantly learn the motion sensor code when triggered, however I am not sure that the 433Mhz events can be passed on to an MQTT or the 433Mhz receiver is ONLY to control the KC868 board?
any help is greatly appreciated
K
KCS firmware can learn your RF signal. send out by MQTT command, but will not feedback to home assistant when received RF433M signal. here is mqtt document:
https://www.kincony.com/forum/attachment.php?aid=2872    it showed:
8. Send one RF signal have learned
send: {"run_rf":{"value":1}} means: send RF signal that id=1
feedback: {"run_rf1":{"value": success}}
if you want RF sensor trigger other actions, just make AUTOMATION in home assistant. you can config ESPHome to receive RF signal then make AUTOMATION in HA.
(01-12-2024, 12:19 AM)admin Wrote: [ -> ]KCS firmware can learn your RF signal. send out by MQTT command, but will not feedback to home assistant when received RF433M signal. here is mqtt document:
Sorry not sure I completely understand... but I don't want to change the firmware on the board.... if I understand this correctly, can I configure the KC-868 IFTTT to transmit on a receive event, and use the kc868 transmit event via MQTT??
if you send MQTT command to A16 board, A16 send RF signal . it's OK.
just send out (learned by KCS) RF signal by MQTT command.
