Full Version: KC868-A16 Download, EtherNet Firmware and not open EntherNet
Attached...
when you download firmware, remove the RF433M receiver module, it will be solved.
When I removed the RF receiver and transmitter and reconnected the module to the PC via USB cable => download to the module was successful.
Now the A16 module is available on the LAN and I can configure the inputs and outputs.
Thanks for your help!
ok, good.
I have a similar problem, but the result is different. the installation runs correctly, but the LAN port does not turn on after connecting the cable. when installing TASMOTA, I have access to the board via WiFi, the LAN LEDs light up, but I do not receive the LAN address via cable.
Web_server installation always ends the same, LAN does not work.
LOG:
*************************** START ****************************
START TIME: 202408192221
CONNECT BAUD: 115200
set state: ESP_DL_SYNC
serial port opened
baud:115200
root baud:115200
===============BAUD : 115200===============CALL DEVICE SYNC
connecting...
chip sync ok
mac l: 0xf74947b4
mac h: 0xe008a6
crc_cal: 224
crc_read: 224
crc_test: 0
ESP32 MAC CRC OK
get mac res: 1
get flash id : 0x0016405e
manufacturer_id: 0x5e
device_id: 0x4016
Wrote 743200 bytes (422165 compressed) at 0x00000000 in 37.0 seconds (effective 160.6 kbit/s)...
Hash of data verified.
Leaving...
com closed
Use time: 39 s
Download result: PASS
*************************** END ****************************
when download firmware, remove RF433M reciever.
if you have problem, upload some photos , so that can understand.
