i have the KC868-A16 REV:1.6 new and try to connect ethernet port and no open or no can see the lights, and connect to Router or my laptop, none show the ethernet port connect.
download the firmware "KC868-A16_Web_Server_Eth.ino.nodemcu-32s-202209151019.bin" install whit a ESP32 Download Tool, reboot and not see any change its the same
add these 1-3 item files. download every zip file, unzip it, will have the BIN file.
attachment=3926]
With these files works, and try with the firmware "KCS_KC868_A16_V2.2.2" and works fine but try the firmware "KC868-A16_Web_Server_Eth.ino.nodemcu-32s-202209151019.bin" but does not works. can i install the firmware "KCS_KC868_A16_V2.2.2" and connect to alexa?
How can doit?
sure, you can download KCS firmware, then add to Node-Red by mqtt, then use alexa node for voice control.
(01-21-2024, 07:15 AM)admin Wrote: [ -> ]sure, you can download KCS firmware, then add to Node-Red by mqtt, then use alexa node for voice control.
i Can't find a example for a KC868-A16, how can do that?
if you don't know how to do, the easiest way is use our tuya license and tuya adapter, so that can support alexa and google home.
