Ok I have my KV868-A6 & nRF24l01 boards how do I connect it to my wifi network and home assistant as I can't find anywhere how to connect every thing together I a completely new to once I get the thin connected I mite understand it better s
do you want nRF24L01 work with home assistant?
Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup:
1.Connect KC868-A6 and nRF24l01 boards physically.
2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app.
3.Find the IP address of KC868-A6.
4.In Home Assistant's configuration file: switch: - platform: kc868 host: YOUR_KC868_IP_ADDRESS
5.Restart Home Assistant.
6.Check and test the KC868-A6 switch in Home Assistant interface
Hope this helos, let me know how it goes
(02-22-2024, 11:50 AM)Lucas35 Wrote: [ -> ]Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup:
Can you explain a little bit more detailed this steps?
I want to use KC868-A8.
What firmware should I use for the controller?
(03-26-2024, 06:04 PM)tamibandy Wrote: [ -> ] (02-22-2024, 11:50 AM)Lucas35 Wrote: [ -> ]Connecting your KC868 to Home Assistant involves several steps. Here's a general guide, but keep in mind that specific details may vary based on your setup:
I also need more info, i.e. on the step " 2.Configure KC868-A6 to connect to home Wi-Fi using a web interface or app. "
I just received my KC868-A16 and can't get started with it. After powering up for the first time, I can't see the WiFi network, nor it doesn't connect automatically to my LAN. How to connect to it to start configuring the device?
if you want use A16 with home assistant, just use our ESPHome yaml file.
if you want directly to use A16 board, you can download KCS firmware.
note: when you download firmware, remove the RF 433M receiver module from PCB.
(06-16-2024, 10:29 PM)admin Wrote: [ -> ]if you want use A16 with home assistant, just use our ESPHome yaml file.
Can you please clarify, if I want to use A16 with Home Assistant and ESPHome, is this the yaml file to use?
https://www.kincony.com/kc868-a16-ethern...igure.html
1) The file is badly formatted. Is it available for download with proper formatting?
2) Can you explain where/how to add the file to home assistant installation?
3) Please clarify on the firmware: If I use this one:
https://www.kincony.com/forum/showthread.php?tid=3791
Is this the valid firmware to have the A16 work with ESPHome in Home Assistant?
When I go to ESPHome in Home assistant and click add device, it asks for IP and Port of the device. Should this work with A16?
