Full Version: How to integrate KC868-COLB-MINI using http
Hello All,
I installed a KC868-COLB-MINI on a remote site, I want to integrate it with my system using the http requests, is there any document to do that, if not what are the requests for "TCP Server" working mode?
COLB not support by HTTP integration. mainly use by "TCP Server" mode for HEX format protocol. can you tell me an example function you wanted.
i Want to read all the DI interfaces and the first channel of DS18B20
Also can you provide me the procedure to update firmware in order to support MQTT
now your COLB firmware not support MQTT?
Please provide me the one of "TCP Server"
Kincony colb that i have did not support MQTT, it has an old firmware version, how can I upgrade the firmware, please send me the steps.
here is update details: https://www.kincony.com/forum/showthread.php?tid=2656
if you want to use tuya app, need update BOOTLOADER firstly, because after update BOOTLOADER will support firmware file >128K. if you don't want to use tuya app, just use mqtt, you can download a older firmware supportted MQTT, not need to update BOOTLOADER by Jlink, just skip this step.
here is video tour: https://youtu.be/Uvl0FNVOORs
